Clusters. Merging small cluster area with its neighbors
   1781   2   1
Building from myself some hardsurface procedural methods, one issue i have.. Is it possible to filter generated clusters? Merging small cluster which area is too small or area too stretched to the most adjacent cluster?
Off course, it's also hard to know if the cluster has to be removed or not . I mean in mure term of design, the size should not be the only element to take into consideration, but that's off couse another more complex question
Might i ask if that speak to you ?
Thanks you !
Edited by vinyvince - July 26, 2021 16:56:02
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
Here is one possible solution [forums.odforce.net] to your problem as provided by konstantin magnus on the odforce forums.
Hey Jikian
Thanks you, Im afraid it does not. My clustering is not based on the voroinoi diagram, i know these tricks but can't apply it in this case.
