WIP - StartFrame Solver [Houdini Utility]
   6687   1   6
HDA Now Available!
Your feedback is precious to develop the better experience possible. More in the next post.
Hi All!
I recently learned to use Python in Houdini. This is my first attempt to create a tool that includes some lines of code.
Description
Detect the frame at which attribute reaches given conditions. Then create and store attributes on points:
@startframe attribute corresponding to the frame the change occurs.
@triggered attribute corresponding to based on point's state.
‎‎‎‏‏‎ ‎‏‏‎ ‎‏‏‎ ‎‏‏‎ ‎‏‏‎ ‎‎‎‏‏‎ ‎‏‏‎ ‎‏‏‎ ‎‏‏‎ ‎‏‏‎ ‎‎If @startframe's value match current frame, @triggered is set to 1.
@id attribute sorted by point's start frame.
• Node Type: SOP.
Features
• Condition to reach to trigger computation
• Visualizer for @startframe, @triggered and @id attribute.
• Dynamic label that return simulation data (@startframe of the first and last point to be computed).
Use cases
• Synchronize animations or simulations(drive switches, trigger simulations one after another,...).
• Get additional data from animation or simulation (@startframe can be used to determine age, life, contamination speed, ...)
Previews
Visualizers:
Startframe
ID
Trigger
Interface:
User Interface
Geometry Spreadsheet
Help File
Under construction
Edited by JohnFanny - Sept. 29, 2021 08:11:12
John Fanny | Fx Artist
Example Video
A quick video showing some use cases of the Startframe Solver in Houdini.
HDA Now Available!
Edited by JohnFanny - Sept. 29, 2021 08:43:08
StartFrame Solver_0.11.zip (312.3 KB)
