A radial menu for radial menus?
   3122   3   2
I rely on radial menus heavily and have made a lot of custom ones. The one thing bothering me is that there is no way to quickly switch between them. I have to go to the main menu and choose one for hotkey 'C'. I put my viewport on my second monitor, so it's not as quick as I want.
The ideal solution for me is to have a radial menu that allows me to switch the current radial menu, so I don't need to leave the viewport quite so often. But I'm not sure how to achieve this. https://www.sidefx.com/docs/houdini/hom/hou/RadialMenu.html [www.sidefx.com] doesn't have a setCurrent() method or something. I tried to call hou.ui.injectRadialMenu() but it did nothing.
Is it possible to set up a radial menu for radial menus?
Edited by raincole - Feb. 4, 2022 12:22:46
Have you tried this
Edited by CoreSign - Feb. 21, 2022 00:01:33
Did you find a solution to this?
I tried to work around this by calling another menu with python
kwargs['pane'].displayRadialMenu('create')
But Houdini hates it and keeps crashing.
See, if this helps:
https://www.sidefx.com/forum/topic/93335/?page=1#post-453369 [www.sidefx.com]
