Hi, is there a feature for proportional keyframing? In Maya, they are called Breakdown keys. In After Effects, they're called Roving keyframes.
Basically, any keyframes that lie in between 2 keyframes will adjust their timing automatically as I drag the end keyframes across time.
Proportional timing for keyframes?
1831 2 1-
- eikonoklastes
- 448 posts
- Enivob
- 2659 posts
- eikonoklastes
- 448 posts
Thanks, I am aware of that, and that's what I currently use as a workaround. It requires a selection every time I need to do it though.
Also, if there are other curves visible that should not be part of the scaling, I also need to remove them from the view first, or carefully select around them. Not very efficient.
Another useful feature of it, is that it is usually drawn differently from regular keys, so it makes it easier to visualise, at a glance, which are your key poses, and which are the in-between keys.
Curious that this feature does not exist, given how common it is in animation apps.
Edited by eikonoklastes - March 12, 2022 02:04:29
