How to Delete Variable from Variables Window?
   2137   4   1
I have added a variable in the Houdini Variables Window (Edit->Alias and Variables) Window for debugging purposes.
Now that I no longer need this variable, I want to delete it from the Variables Window.
However, when I select the variable, then delete the text from the two fields at the bottom, the Variable is still there!
How do I remove a variable from the Variables Window?
When I right mouse on the variable name, there is no Delete popup menu.
Edited by jlapre - June 7, 2022 14:28:54
Screen Shot 2022-06-07 at 11.25.37 AM.png (531.7 KB)
Jeroen
set -u VARNAME in the hscript console
I might submit an RFE for right-mouse on the variable name delete popup menu.
As hscript is ancient technology and increasingly hidden.
Jeroen
jlapre
I think if you just delete the text for the value it does the same thing.
I tried that, but the variable persists.
I submitted this as RFE ID 122055
Jeroen
