Vellum Balloon Inflate controlled by an attribute problem
   2064   1   1
Hello everyone,
I'm quite new with houdini and I'm trying to make a simple animation where I control the inflation of a balloon by an attribute.
In this case the setup is quite simple. I copy some sphere onto a grid, and control the color attribute by the distance treshold on the attribute transfer node.
Then I remap this attribute and change the name to "inflate_value"
After the vellum set-up I tried to change the value on rest length scale to the name of the attribute, but didn't make it work. I also tried VEX to assign restscale to the name of the attribute but didn't work either.
How would you do it? Attached is the file.
Thanks in advance!
Vellum_inflate_test_color.hiplc (502.1 KB)
Before your copy to points, set up timing and inflation ranges.
// Set inflation range.
f@rl_start = 1.0;
f@rl_end = 3.0;
i@color_id = @ptnum;
// Randomly choose start and end frames for each sphere.
i@start = int(fit01(rand(@ptnum),6,36));
i@end = i@start + int(fit01(rand(@ptnum+801),6,36));
Then inside the solver, use a Vexpression to deploy the restlength at the appropriate time.
// Fetch attributes as local variables.
int start = point(2,"start",@ptnum);
int end =  point(2,"end",@ptnum);
float rl_start = point(2,"rl_start",@ptnum);
float rl_end = point(2,"rl_end",@ptnum);
// Supply varying restlength.
restscale = fit(@Frame,start,end,rl_start,rl_end);
Edited by Enivob - Aug. 18, 2024 12:39:56
ap_Vellum_inflate_test_color.hiplc (493.7 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
