how do I phrase an "if("float" is > 90 but < than 180)"
   1591   6   2
so I have worked out how to do my trigonometry in vex. But I am confusing myself with the "if" question.
I need to get a value within a range? my heads broken.
sussed it out
if((name > 90) && (name <180))
do this;
Please correct me if I have this wrong
That looks correct but you don't need extra parentheses;
if ( name > 90 && name < 180 )
I've always hoped to be able to do
if(90< name < 180)
it'd make it faster to type and to grasp on quick look
Andr
if(90< name < 180)
That's a scary expression, because it would look like it's working, but it'd evaluate (90<name) first, giving you 0 or 1, which is then always less than 180, so the expression is always true. If it worked in VEX, it would bite you when you started programming in some other language.
ah, thanks!
@animatrix_
Thanks for the tip ;-)
