How to switch active radial menu programmatically?
   1190   1   1
I'm trying to use radial menus more in my workflow. However, selecting which radial menu to activate from this menu is a bit tedius:
I know I can set a hotkey for each radial menu. But I think a better way is to make a "radial menu of radial menus", where I can switch the active radial menu. To do so I need to:
1. get a list of radial menus in python
2. switch active radial menu in python
What's the API for this?
Screenshot 2023-12-01 225534.png (31.3 KB)
To get a list of radial menus:
hou.ui.radialMenus()
You can check, which menu is active with:
hou.getPreference('radialmenu.val')
Also you can set it with:
hou.setPreference('radialmenu.val', '2')
But... menu bar doesn't refresh and it updates when I hover cursor over radial menu option. I suppose there's some command to run after setting preferences. I don't know.
One thing to note - I haven't tested this solution properly and I'm not sure if this is the right way to do it. Use it at your own risk.
