Storm render to disk
1988 1 0-
- Latimerias
- 41 posts
- mtucker
- 4574 posts
You can use a USD Render ROP if you change the Render Command (on the Output tab) to `usdrecord` instead of husk (or `usdrecord.cmd` on Windows). If you do this, not all of the parameters will work of behave the same way because husk provides a lot more command line options than usdrecord. But usdrecord will run Storm as the renderer.
