Simple python callback -- what am I doing wrong?
   1556   2   1
Hello All,
Here I have the world's simplest python SOP, and I've added a button to its UI that when pressed I'd expect to call main() in the python code. Instead, when pressing the button, I get the error "AttributeError:'module' object has no attribute 'main'
I've defined the UI for the button so that the callback script is
hou.pwd().hdaModule().main()
The code in the python node is simple:
node = hou.pwd()
geo = node.geometry()
# Add code to modify contents of geo.
# Use drop down menu to select examples.
def main():
print("in main...")
#main()
Clearly I'm doing something wrong, but I'm not sure what. All explanations would be most welcome!
Thanks very much,
Mary
simple_but_broken.hip (89.2 KB)
Python SOP code is not HDA module of Python SOP
code within Python SOP is executed when the node cooks as it's meant to modify geometry that the node owns during cooking
if you want to excecute random piece of python code, you can either use HDA and define it in HDA module, or you can even use any String Parameter and exec() function
simple_example.hipnc (96.8 KB)
Oh my goodness -- that clears things up tremendously.
Thank you, Tomas!
Mary
