Trouble setting UProperty GeneratedFoliageDefaultSettings
   1173   0   0
I receive the following error trying to set the Uproperty GeneratedFoliageDefaultSettings on the Houdini side: LogHoudiniEngineRuntime: Warning: Could net set object property GeneratedFoliageDefaultSettings: ObjectProperty's object class (FoliageType_InstancedStaticMesh) does not match referenced object class (Class)!
My vex code is in a detail wrangle as follows:
s@unreal_uproperty_GeneratedFoliageDefaultSettings = "/Script/CoreUObject.Class'/Script/HoudiniEngineRuntime.HoudiniInputFoliageType_InstancedStaticMesh'";
I've also tried setting using the string value as follows:
s@unreal_uproperty_GeneratedFoliageDefaultSettings = "Foliage Type Instanced Static Mesh";
The Unreal type is listed as an ObjectProperty and the Houdini type is listed as a String. Any ideas how to set?
