cant render as a png
   1417   1   0
I'm trying to render out a scene so that it has a transparent background. and in order to do that i need to render it as a png
although when i try to write .png in the end of the other text and render it it still just gives a non transparent picture. i dont know if this is because it isnt a png or if its because i have no idea how to render stuff.
Edited by goofington - Jan. 25, 2025 13:25:57
snowman scene.hipnc.copy2.hipnc (1.9 MB)
They do render as a png with alpha here.
If you want to see the alpha channel in mplay press the alpha channel button below the image (or hotkey 4).
You have the render rop Override Output image set to "ip", which will send the renders to Mplay and will not save them to the directory you specified in the settings node. If you want the files on disk (other than wherever mplay caches them) you would then need to save them from the Mplay menu bar.
Instead of that you may want to scroll down a bit to the husk > monitor > enable mplay monitor, that way if you hit render to disk the files will actually be saved where you wanted them, but mplay will monitor the render.
Also, you may want to take a look at your project directory structure.
Where you see $HIP in a save or load path, that is a reference to the location of the current hip file, so houdini is looking to save your output image in a subdirectory /Documents/blender projects/Goofertons projects/houdini projects/snowman/ located next to your hip file, (not in your users documents folder, which you may be expecting.)
