Following up from a thread on the sidefx-houdini-list, I'm attaching a script that stacks circles inside a shape. (The hscript version posted to the list had line wrap problems.)
This approach uses the dual of a delaunay triangulation of a shape, some least-squares adaptation, spline fitting, etc to pack circular shapes inside an object in a quasi-random manner. The result is fairly organic cellular composition.
packed circles
14281 8 4- tstex
- 454 posts
- tstex
- 454 posts
Here's an extension - or variant - of the above network. (You need to have run the above script before you can run this one.)
It's along the same lines of the above script - using the dual of the delaunay triangulation - which is just a voronoi breakup essentially:
http://www.comp.lancs.ac.uk/~kristof/research/notes/voronoi/ [comp.lancs.ac.uk]
It would be great if SESI could wrap this up into a SOP that had the additional ability to preserve the boundary of the original shape, and beyond that, handle 3d shapes…
Enjoy!
Enjoy!
- syzmatrix
- 111 posts
- tstex
- 454 posts
- tstex
- 454 posts
- arzo
- 99 posts
- 8599 posts
- fsimerey
- 279 posts
It's far away the approach of post in houdini-list and this link
http://paulbourke.net/texture_colour/randomtile/ [paulbourke.net]
Your approach never give you a big difference between the bigger and the smaller shape.
A VEX or python could do this.
- sly
- 28 posts
fsimerey
thanks for the link ! very interesting
