Get size of bbox of previous copy
7389 8 2-
- SreckoM
- 381 posts
- 9631 posts
if you need just previous one, you can compute it in the left copy branch as well and then use that info, but if you need all previous ones, it's better to use another solution (like for each, or maybe you can know all the sizes before and just use that info) but that depends on your actual problem
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- rafaels
- 702 posts
Agree with Tamte, the best bet is to know your bbox beforehand and use expressions to figure out the current copy based on the previous one…
On the other hand you can use a VOP SOP to go through the points and setup the bounding box sizes (overall scale of the intended copies) as point attributes and then apply those values to the copies as stamping attributes. That's how I solved a similar problem I had, although I was traversing points in a line so it was an easy one-way comparison anyway.
Toronto - ON
- asnowcappedromance
- 512 posts
- SreckoM
- 381 posts
Thanks for response guys!
What I need to do is similar to books on shelf. I need to generate several of them, random sizes and than to place them on by one. I might go with Python SOP just need to learn more about Python in Houdini. This is something I created in Maya with Python, for practice I am transferring scripts to Houdini.
- rafaels
- 702 posts
If you build the books procedurally then you can specify the size based on the position rather than the opposite. It'll be much more straightforward and indistinguishable for the viewer.
Toronto - ON
- SreckoM
- 381 posts
Thanks for help.
I manage to do it with copy, distance() and attributes
Here is short video of where I am now. It requires more tuning.
http://screencast.com/t/yWCmmNpx1T9o [screencast.com]
I really need to learn more about Python in Houdini.
- rafaels
- 702 posts
looks really good, man! congrats!
Toronto - ON
- SreckoM
- 381 posts
I finished this as book generator. Here is video and some pics, really fast way of generating a content for libraries
http://screencast.com/t/suPXAMeYiY [screencast.com]
