I can't export frames using Houdini's flipbook. Houdini quits flipbooking after rendering first frame with this error message:
“Image file save error: Unable to create image …”
Flipbooking directly to MPlay is working, but I'm getting a lot of drop frames. For this reason it's a useless workaround exporting frames with MPlay to disk.
I've checked out every GL Mode in the “3D Viewports” preferences.
I also tried a fresh Houdini installation and I cleaned the Houdini profile in “users/my documents”.
UAC is turned off and I've all privileges to write to the desired destination folder.
Using a “OpenGL ROP” instead flipbook export is working (same destination folder), but I'm getting different results compared to the viewport display. So it is difficult to control how the written image looks like.
In H11 everything is working pretty well.
Any ideas?
Thanks a lot,
Peter
Windows 7 64Bit, Quadro 2000M, Latest NVidia driver (295.73), H12.0.0560 Apprentice
H12: Flipbook issues
11010 6 0-
- Pittiplatsch
- 14 posts
- Pittiplatsch
- 14 posts
- SreckoM
- 381 posts
- オンライン
- Pittiplatsch
- 14 posts
- Pittiplatsch
- 14 posts
- Pittiplatsch
- 14 posts
I've found a solution for the “file save error” problem. It has something to do with general output resolution limitation with Houdini Apprentice. Reducing the flipbook output size to 720x576 or below helps a lot
, sounds sensible to me.
ops:
But the drop frames issue when flipbooking to mplay still exists.
ops:But the drop frames issue when flipbooking to mplay still exists.
Windows 7 64Bit, Quadro 2000M, NVidia driver (331.65), H12.5.533 Apprentice
- vishuz10
- 4 posts
