Toon shader in Houdini?
   9326   6   4
Hey guys,
I'm working on an effect for a thesis project and I was wondering if houdini had a toon shader that I could apply to fire?
Not built in but it is easy to make one using a Ramp parameter multiplied with the density.
Drive, monkey, drive!
what would be the input of the ramp?
I modified a basic smoke shader and although it worked as I expected, I'm not really sure it is what you expected…
I basically just intercepted the surface color and piped it into a ramp. I then multiplied by the opacity to make sure the empty voxels would remain transparent.
Hope it helps.
test_volume_shader.hip (425.6 KB)
Toronto - ON
also ive seen people on vimeo first convert the sim into a solid, you could take one of your fields and use a convert volume and then shade them with a normal stepped toon shader. i will try and find an example of it and post it here
here is an example https://vimeo.com/37351479 [vimeo.com]
Yeah… meshing the volumes would probably be a lot better, although I don't really dig the look!
Toronto - ON
