Hey everybody, Does anyone could give me an example of the modulus function in expression? since i very confused about this function.
Thanks.
modulus function
22702 7 3- nenuco
- 18 posts
- animatrix_
- 4530 posts
You can use:
5 % 2
to get the remainder 1.
More info here:
http://www.cprogramming.com/tutorial/modulus.html [cprogramming.com]
You can use:
5 % 2
More info here:
- nenuco
- 18 posts
- bollili
- 205 posts
- nenuco
- 18 posts
- nikmolson
- 54 posts
- bollili
- 205 posts
A bit confusing is the use of the word modulus in (british?) english. The absolute value function abs() is often called modulus.
see here (first paragraph) – abs() in Houdini
http://en.wikipedia.org/wiki/Absolute_value [en.wikipedia.org]
vs. here – % in Houdini
http://en.wikipedia.org/wiki/Modular_arithmetic [en.wikipedia.org]
- old_school
- 2540 posts
Modulus is used to create “sawtooth” channels from varying data (channels, attributes, sequences of images/geometry, etc).
For example you can take some geometry with the same number of points per row and create values for each point like:
$PT%100
where 100 is the number of points per row and would return 0-99 for each row in your geometry. Comes in handy for a very lightweight way to set increasing attributes on curves for fur/hair/grass that have the same number of points per curve where you don't have access to the SOP network or geometry loaded in from disk.
Modulus is used in crowds all the time. Either for cutting up a path in to strides and then index in to the right motion geometry or channels.
Countless other uses where you can identify a repeating pattern and you wish to work with it.
$PT%100
