Quadro K4000 performance
45748 56 0-
- anon_user_37409885
- 4189 posts
- misterluqman
- 28 posts
- frescalus
- 25 posts
Just out of curiosity, which driver version is being used?
I have Realflow and it's found some driver versions aren't very good and cause issues with performance so I'm wondering if that's the same here if anyone has tested?
I have 320.86 right now, but I also see some are using other versions.
I got 5.2fps on mine with the same torus setup on the grid.
Can you test with other driver versions and see what happens?
-----Neil
- kevinthebright
- 225 posts
- misterluqman
- 28 posts
I also had that issue with Realflow which was fixed by Nvidia with the 320.92 drivers. So this is the driver I'm runnig at the moment. I also testet older drivers. The results are all the same. Ubuntu with 319 also same. I even did an RMA on the card to be absolutely sure it is not a hardware problem. I assume the k4000 was not the right choice for Houdini. In Max and Maya it performs well.
- misterluqman
- 28 posts
- chrism
- 2619 posts
- frescalus
- 25 posts
- chrism
- 2619 posts
We're getting around 150-170 fps when tumbling around with that torus/grid scene on our k4000. Not sure what the difference is between our machines, but at this point you should log a bug and provide support with your specs from Help > About Houdini, along with your scene file. Thanks!
Chris McSpurren
- misterluqman
- 28 posts
chrism
4.2 - 3.9 fps which would make your viewport about 40 times faster than mine which makes me doubt that we are running the same test.
Just before I start filing any bug reports, would it be possible for you to confirm that we are testing the same by downloading the attached file and run it on your machine. Maybe I did something really stupid which I am not aware of.
I am testing with GL 3.3 and shadingmode “Smoth Wire Shaded”.
The Hardware is not that bad, it is a dual xeon 5680 workstation overclocked to 4.2 Ghz.
Edited by - 2013年11月2日 08:24:45
- igor_donev
- 133 posts
- malexander
- 5301 posts
- 4189 posts
tricecold
I heard so many stories like yours i myself did not go with a quadro or firepro but went and purchased a 3 GB 7950 and shot my self again in the foot.
It turns out this card HD7950 sucks in Houdini big time,
I am not joking but a meshed sea surface with waves 3.5 mil poly only , on default viewport in maya 3.1-4 fps (its not acceptable but for a consumer card its ok) and then we jump into viewport 2.0 powered by dx11 and i get between 80 and 115 fps can you beleive it. VP 2.0 is limited but it gets its update slowly, and from what I saw at the technology preview at annaheim itr seems like it will be the new default of maya soon……
now the same scene in Houdini the card perfroms in GL3.2:1fps and H11 viewport gives me actually 7fps but no shading just black object.
I reckon you should re-run your tests now that Houdini 13 is out
50+fps 3.2mil primitives waves headlight only, smooth shaded
25+ fps 3.2mil primitives high-quality lighting & shadows(antialiased-area), smooth shaded
H13.0.222, AMD 7950, OsX 10.9, GL2.1 viewport
- papi
- 37 posts
- 4189 posts
- misterluqman
- 28 posts
With MartybNz's scene on the k4000:
9.9 fps headlight only
1.8 fps HQ
Great card!!
So what to do? As I get the same results on W7 and Ubuntu with the latest drivers.
A software problem can probably ruled out. Anyway I installed W7 AND Ubuntu completely new ONLY running Houdini 13. Same result.
So it must be a hardware issue.
I already did an RMA on the k4000. Same result.
Tried the card on all slots. Same result.
Ran the System on each CPU seperatly. Same result .
Tested the RAM modules seperately. Same result.
Tried 3 different monitors with differet resolutions. Same result.
It is probably not a Hard Disk related problem so I did not test that.
Just to emphasis this again the card runs fast under Maya and Max. I also did some benchmarks - card runs fine.
This is a problem only related to Houdini and - if I look at Chism' s results - only related to my setup.
Anybody an idea before I do an RMA on the Motherboard?
BTW: The HQ lighting in Houdini 13 looks beauifull and I did a comparison between Mantra and Arnold. – There was absolutely no difference exept Mantra is somewhat slower.
Great update!!!
1.8 fps HQ
Great card!!
Great update!!!
- 4189 posts
- igor_donev
- 133 posts
- motionprojects
- 4 posts
I have been using active (quad buffer) stereo in the viewport with H12.5 succesfully, using 3d vision 2 shutter glasses and gl 3.2. On an Asus VG278HE monitor. Quite nice actually.
However H13 on gl 3.3 when stereo is enabled – my objects disappear (the transform gizmos remain). If I demote the H13 viewport to 2.1, quad buffer stereo resumes working
I've messed around with every nvidia and Houdini display setting I can think of, but can't seem to have my gl 3.3 viewport and active stereo alongside.
My nvidia drivers are up-to-date.
Other than this I have no other viewport or speed problems.
Windows 7 pro sp1
nvidia k4000
Windows 7 pro sp1
nvidia k4000
- andrej22
- 15 posts
misterluqman, did you solve this problem maybe?
I've got k4000 on dells' precision dual xeon, 64 gigas ram, machine and my viewport performance is 3 times worse comparing to my other machine which is i7, gtx 780, 16gigs ram.
I've got around 8 fps on that torus-grid scene on k4000 and 25 fps on gtx 780.
The funny thing is, I get twice more fps on GL 1.2 comparing to GL 3.3.
I've compared max and maya. Max Nitrous and maya ViewPort 2.0 work 3 times faster on gtx 780, but that's alright I guess since they are using DX. On maya openGL viewport I get about 5 times better performance on k4000. But who cares when 2.0 is still a lot faster.
I'm rly starting to wonder what's the point of quadro cards. Nvidia is conviencing their users these cards are made for applications like houd, maya, max and yet GTXs are owning them badly in all apps.
