Files are now Non Commercial!
   17044   6   2
Hello there!
i am working on a project with my Indie license, really gratefull for the indie option.
I just opened my files and I am getting an error that I entered the non commercial mode which is kind of a problem because I need to start rendering those files in 1080p watermark free very soon.
Can I convert them back to Limited Commercial?
by just copy pasting I am getting (as I paste) the same error ‘entering non commercial mode’…
What's wrong? It happened when I used VDBfromPolygons for my static mesh.
Thnks, hope you guys know!
Best regards
Giso
オンライン
this can happen if you ever (at any point) use a non-commercial HDA, or (and this happens to me all the time) copy and paste ANYTHING from a non-commercial file into another type of file (hip, hiplc)
there is a one time conversion that can be done by SESI but you'll have to contact support directly as I don't know how that is offered or to who.
otherwise - you'll just have to sit down and re-build your scene node by node - DON'T Copy and paste - with your current file as reference.
HTH
Training Lead
www.sidefx.com
Hi Arctor,
I am afraid I have to re-build it, just copy pasting gives me instantly the same error
But I'll give SESI a try first.
thanks for the reply!
Giso
オンライン
just to be clear - this isn't an error, it's a restriction of using a non-commercial license.
Training Lead
www.sidefx.com
You can convert Apprentice files back to Indie files using this utility:
http://www.orbolt.com/upgrade-houdini-files [orbolt.com]
thanks for the help arctor and rmagee.
I tried to convert it, didn't work the first time.
It appeared my sim's Initial Frame was created with the apprentice version (don't know why or how, because I made it myself) … Anyway removing the Initial Frame I was able to convert it and re-sim it within the Indie environment.
thnks again for the replies.
Giso
Check “backup” folder inside hip directory if there any backup file .
