How can you stamp attributes from a Point Vop?
   4968   4   2
オンライン
Hi there,
I was just wondering, from within the copy node it's easy to stamp point numbers ($PT) and colours ($CR) but how could I stamp a custom attribute I have created from within a point Vop?
Thanks,
Pete
Just put the attr name into the attribute stamps parameter.
Then when stamping, use the attrib name directly, eg
stamp('../copy1/','ScaleTweak',1)
オンライン
Awesome! Thanks for that!
or you make it a local variable.
I just found out about this 10 min ago
look here:
https://vimeo.com/158037926 [vimeo.com]
at about 13 min
G
nooooOOOOOO! :wink:
Try and wean yourself off of local vars, the general push is for everything to become unified under @syntax.
