Twisted curve and sweep SOP
5173 4 1-
- Unaided
- 49 posts
I have this problem with a twisted curve when I use a sweep operator. I see sweep sop it have Twist control, but I can't use it handly to fix this issue.
The curve is generated by a equation from wrangler, and must be a close curve. I've tried closing curve from code and with ends SOP.
I need have to control closing point of curve profile at start and at ends from sweep operator, else for curve rotation.
- Konstantin Magnus
- 671 posts
- Unaided
- 49 posts
Uploaded hip file.
I've seen the problem appears when the equation curve is heavy twisted. With a simple circle for example, works as expected when arc is closed in the same Circle SOP or keep arc opened, then using Ends SOP to close it.
I think in a way to control the ends up vector, but maybe there is a easy solution to keep a correct curve continuity respect its points orientation.
- circusmonkey
- 2624 posts
- Unaided
- 49 posts
Thank you circusmonkey!
Using your method with Polyframe andcopyOp instead SweepSOP tangent + normal attributes, it seems works ok. Using a open profile and close with SkinOP is valid for my purporse too.
After I've seen that it have a bit of twist in the ends of curve. However it's suitable in most situations of twist and divisions.
It would be possible add a value to an attribute?
I want to try adding a small increment to current normal to attempt compensate the current deviation.
Edited by Unaided - 2017年1月3日 10:44:03
