How I can avoid dive into network when a null be selected?
I want to create a digital asset, but I don't wanna this behavior.
Avoid dive into network when select
4308 7 1-
- AlbertoGZ
- 42 posts
- 9434 posts
- AlbertoGZ
- 42 posts
Thanks for your reply tamte
In fact I want to avoid this behavior in asset, but turning off “Allow diving into locked assets” is not working for me. Maybe I have set both nulls into “editable nodes” for asset properties, to make available them can be select and move it.
As well as, I would like a way to avoid dive into network that aren't dependent user preferences.
- AlbertoGZ
- 42 posts
I've been found a way to allow manipulate nulls inside asset preventing dive automatically into network when nulls are selected, too without need add them as editable nodes.
This way consist by adding a vector3 custom parameter in root level of asset and link to tx,ty,tz for my nulls in my case. However the custom parameter must be visible
Edited by AlbertoGZ - 2017年2月2日 14:27:29
- 9434 posts
- AlbertoGZ
- 42 posts
Thanks tamte!
I don't know if exists a better method but to solve that promoted parameters be visible, instead to use “invisible” option, I have created an extra custom parameter as integer (as invisible), and I use the option “hide when” to hidden the promoted paramters by value of this extra parameter.
- jerry7
- 680 posts
- AlbertoGZ
- 42 posts
jerry7I unknew that behaviour be a bug… so its certainly can be annoying dive into network each time a item is selected.
I have reported this bug many monthes ago. I suggest you report it again to promote sesi repair it.
H16 is about to release, so maybe we can wait to see this is fixed. Otherwise I report once again this bug.
