Hi all!
I'm loving the new point bevel option on the poly bevel sop node but for some reason it's crashing one of my scenes. I'm just trying to round out the corners of this -
No idea what's causing it but if anyone has any suggestions it'd be great!
Pete
Point bevel crashing
3718 5 2- peteski
- 517 posts
- Enivob
- 2539 posts
- peteski
- 517 posts
- adburns
- 20 posts
- bardia
- 210 posts
There are two separate issues here:
1. The crash is due to bug that is fixed in 16.0 but was forgotten to be back-ported to 15.5. I'll take care of that presently.
2. Point bevelling only works on the interior points of the same polygon curve. When you fuse the end points of two distinct primitives, you still have the joint shared by two primitives. As it stands, this is rejected by polybevel. You'll need to use join together with sort (on vertex order) to turn the result into a single curve.
- peteski
- 517 posts
Thanks bardia,
Hey out of interest if you join a bunch of curves together as there a way so sort so the numbers flow from one end of the new single curve to the other? I never seem so be able to find an option that will work for a complex curve shape.
Just wondering if I'm missing some cool trick for that.
P.
P.
