Scatter points density based on color
13233 7 2-
- gswartz
- 24 posts
I have an iso offset node feeding into a scatter points node. I wanted to use the color attribute of the geometry node (which I had changed with a couple of paint nodes) to feed the density of the scatter points. But the color attributes are lost in the iso offset. Being new to houdini I have no idea how to get the Cd attribute after the paint nodes into the scatter points node to influence the density. Any ideas how to make this work? Thanks.
- 8221 posts
For scattering from volumes, the density of points is determined by the density of at each point of a single voxel grid. The iso offset is creating a density volume that is constant inside your geometry. To drive the density from an attribute on the geometry, a volumetric representation of the attribute is required. If you prefer working with houdini volumes, the node, attribute from volume can generate a volume from an attribute on your source mesh, and optionally multiply by your existing volume – this will preserve the edge blending of your iso-offset. Alternatively, the VDB toolset will allow for similar construction of volumes, often more efficiently than Houdini volumes. You will need to use a vdb combine node to perform the scale by density however.
A point of contention for both methods is that your painted attribute is only defined as a surface, how the value is extended into the volume is not well defined, and most operations will either streak the surface value into the interior along the normal/gradient direction, or simply leave the interior undefined (zero).
- gswartz
- 24 posts
- Mohanpugaz
- 176 posts
you could scatter points separately on the geo using color and scatter points using volume separately then merge both using merge sop then feed it into the voronoi fracture node so that your painted density will remain same in the surface. for scattering inside the volume you could add noise to the volume using volume vop and then use scatter for noisy scattering.
Mohan Pugaz
movfx
movfx
- Isaac Katz
- 18 posts
- Mohanpugaz
- 176 posts
Isaac Katz
Can you explain how this would be done? I only see Generate by Density option on the Scatter node. Thanks
simple example for scattering based on color this doesnt have solution to the original post, this is just for Isaac's question
Edited by Mohanpugaz - 2021年9月3日 05:53:12
Mohan Pugaz
movfx
movfx
- Mohanpugaz
- 176 posts
- Isaac Katz
- 18 posts
MohanpugazIsaac Katz
simple example for scattering based on color this doesnt have solution to the original post, this is just for Isaac's questionImage Not FoundImage Not Found
Thanks!! so simple
