Baketexture from hipoly to lowpoly renders only white/black image without details
   4016   3   1
I'm trying to create procedural rock generator and during tests with creating normal map from hipoly version to lowpoly I hit a wall.
Gernerator creates UVs for lowpoly version:
Added baketexture node in Out Networks, and after setting UV Object1 to lowres version of generator, and HighRes Object1 to hires I got (black/white image without any details for all output formats, tangent-pace notmal, displacement, occlusion, cavity, etc):
I tried also use scaled up version of lowpoly geometry to use as UV Cage Obejct1 with exactly same result.
What am I doing wrong? I could use xnormal after exporting both geometries to obj files but as Houdini allows that approach it could be nice to have this all-in-one place, generator will be used to create different variants of rocks as game assets.
Thanks for help… I figured out it myself, it may be worth for someone in future: it was enabled by default Disable Lighting/Emission (undocumented option as I see).
I must say, Your docs are crap SideFX - hope you'll fix that soon
http://www.sidefx.com/docs/houdini/props/mantra [www.sidefx.com]
It's the first property if you search for “Baking Properties”. We'll see about updating the Mantra User Guide.
The help page for the bake texture render node could use a refresh. Not very many of the default properties are mentioned, and some tabs are completely omitted.
