How can I access the new “make circle”-function procedurally?
(I also asked on http://forums.odforce.net/topic/26204-make-circle-sop/ [forums.odforce.net] a few days ago.)
"Make circle" as a SOP?
5705 10 2- Konstantin Magnus
- 671 posts
- Doudini
- 333 posts
i dont think the make circle is implemented as a SOP.
but you can use this:
http://orbolt.com/asset/mifth::mifth_make_circle [orbolt.com]
- Konstantin Magnus
- 671 posts
thanks for showing me the asset.
isn`t there also a way to call the ‘make circle’-function with python?
- anon_user_89151269
- 1755 posts
It would be cool to have this by default. The problem with relying on scripts/custom tools for lots of simple things is that one has to chase them in the first place, then manage them for each installation which requires time and some mental resources to keep track of what you have/has been installed, etc.
Out of the box for these simple things is always better.
- Konstantin Magnus
- 671 posts
I also dont think it fits Houdini´s philosophy to create a function that cant be accessed with nodes.
- goldleaf
- 4183 posts
Yeah I too was disappointing they weren't available in a procedural-friendly format. I believe I found the underlying functions in the HDK, in case anyone wants to build a SOP or use inlinecpp, until they get in by default:
GU_EdgeUtils.h [archive.sidefx.com]
*edit*
Submitted as RFE #76129
// utility function that will move connected points into circles
// only loops containing points participating in two edges will be moved
GU_API void GUcircleEdges(UT_Map<GA_Offset, UT_Vector3> &edits,
const GU_Detail &gdp,
const UT_Set<GA_Edge> &gaedges);
// utility function that tries to make all connected edges the same length
// each connected island edges will move towards its own target length
GU_API void GUevenlySpaceEdges(UT_Map<GA_Offset, UT_Vector3> &edits,
// utility function that will project connected points along a line
// only points participating in two edges will be moved
GU_API void GUstraightenEdges(UT_Map<GA_Offset, UT_Vector3> &edits,
*edit*
Edited by goldleaf - 2016年6月16日 23:22:37
I'm o.d.d.
- MorganNilsson
- 45 posts
- goldleaf
- 4183 posts
- Andr1
- 118 posts
- animatrix_
- 4549 posts
There are some modeling operations like this one that are not exposed so you can either implement it yourself, or call the HDK function from a C++ Wrangle node and wrap it as a new HDA:
- probiner
- 340 posts
