More elegant way how to place the modules of the autorig on geometry?
1782 8 0- Drasko Ivezic
- 104 posts
I have trouble using autorig because all the modules are too big for my character, and I didn't find a way how to scale the modules down. What is the most efficient way of placement the module elements in the geometry? On the Goldfab masterclass we can see that modules fit perfectly in the character, but to me it seems it was predesigned. Or does the autorig have some algorithm which determines the size of the character? If it does, I haven't see that in the user interface. It is all messy to me and I have trouble understanding the best workflow. Thanks for the help.
- goldfarb
- 3455 posts
- Drasko Ivezic
- 104 posts
- goldfarb
- 3455 posts
- Drasko Ivezic
- 104 posts
arctorYes. Now I upgraded and I can see the scale. But now I discovered different problem.
are you using Houdini 16.5?
Json is wrong, what ever I do.
I manage to make everything work, but the file which is loaded has scale on zero, and then I have to manually put it back on the proper scale. Hands got rotated weirdly, and also feet has to be always manually put back into place. So obviously json is not taking into consideration: scale of the root, manual tweaks on foot module and it rotates some modules back on default, like part of the arm module.
Model scales up
Now, this is unpleasant surprise. On generating the rig, it generates, but model scales up. Why is that? It totally destroys the point in scaling the root down. I did add transform node and scale the model down exactly like it was root, so it was able to capture the bones. But this thing should not happen.
In the meantime I decided this workflow is not good, so I used object merge in geo skin container, and it worked great, without need to scale.
And, now rig kind of works, but capture of fingers not really. I don understand why, because I was really careful in placing all this little boxes in right finger, one after another. So at the end, I still don't have usable rig for experimenting.
- goldfarb
- 3455 posts
- Drasko Ivezic
- 104 posts
arctoryes. Can you see my geo on this file? I am attaching obj, just in case.
can you attach your scene file, I'll try to have a look.
Also, I must say that I played a little, and I added one switch node below the original created geo node from the rig generation, so on the right side you will see with merge object node the scale problem is not there any more. Then I added polyfill node so I make sure there is not some problem there, and it was, actually. So my fingers now kind of work, it could be better, but I think it has to do with lousy geometry and joint placement. I hope you can figure out. And yes, json file is also there, so you can check if this behavior is the same or what is the problem.
Thnx.
- goldfarb
- 3455 posts
- goldfarb
- 3455 posts
