Material to SOP in object merge
11978 13 3-
- NNois
- 174 posts
- anon_user_89151269
- 1755 posts
- NNois
- 174 posts
I'm sorry for the confusion…
Let's restart clean:
In houdini there's 2 way of applying materials
1. Obj way in the obj property, one material possible.
-> Just like Softimage when applying a mat to the root of the geo
2. SOP way where's the material is written in the geo as an attribute with the shader path.
-> In Soft this is just like when you apply a Material to a cluster
-> So what if a material is applied on 1 & 2 ? Well, the SOP way has simply a higher priority and that's good just like softimage.
So far so good ?? well, yes until you want to merge 2 geos, In soft there's a button to merge also the materials and works well because it takes too the root material AND the priority with the clusters
On the houdini side obj_merge wipe completly the OBJ material….
There's a script on ODforce given to Jordi Bares to solve this but this is only sloving it halfly because the script this time wipe completly the SOP materials…
http://forums.odforce.net/topic/19422-object-merge-question/?hl=%2Bobject+%2Bmerge [forums.odforce.net]
So, i'm now 2y later asking if somes had a sort of updated script with the right behavior ;-)
That's not a strange request by the way.
A simple FBX import generate this types of mixed materials…
- 1755 posts
- goldleaf
- 4255 posts
Here's one way; add this bit of Python to a shelf tool:
Now, any selected Obj Merge SOPs will get a Material SOP connected to its output, set to the Obj Node's material.
The attached hip file is an example. Note that the merged and Obj Merge'd geometries all need to have matching attributes. If they don't match, then non of the materials will render correctly.
Hope that helps!
Edit by ndickson: Fixed code block, so that the code is preserved by the forum, instead of replacing quotes, etc.
# Support multiple selected nodes for n in hou.selectedNodes(): # Only operate on Obj Merge SOPs if n.type().name() == 'object_merge': # Set variables for our nodes p = n.parent() m = p.createNode('material') objnode = hou.node(hou.parm(n.path()+"/objpath1").eval()) # Connect the material sop to the obj merge sop m.setInput(0,n) # Point the material sop to the obj's material hou.parm(m.path() + "/shop_materialpath1").set(hou.parm(objnode.path() + "/shop_materialpath").eval()) # Move it below the merge node m.moveToGoodPosition()
Hope that helps!
Edited by neil_math_comp - 2018年5月11日 18:40:16
I'm o.d.d.
- weston.slater
- 4 posts
goldleaf
if n.type().name() == ‘object_merge’:
p = n.parent()
objnode = hou.node(hou.parm(n.path()+“/objpath1”).eval())
m.setInput(0,n)
hou.parm(m.path() + “/shop_materialpath1”).set(hou.parm(objnode.path() + “/shop_materialpath”).eval())
Hope that helps!
I'm trying to do exactly what you have here, however, i'm getting python errors when I try to execute the script. Do you have any idea what I'm doing wrong? I really appreciate any guidance!
(I seem to be having trouble uploading, so here's Drive links to the images just in case):
The Code:
https://drive.google.com/file/d/1Dr3cjunpq_rNvPVNKskRaM2VYr4t8rJD/view?usp=sharing [drive.google.com]
The Error:
https://drive.google.com/file/d/1lagdSwj5bILW8eY_raYzQ9HYt8ydjvBp/view?usp=sharing [drive.google.com]
Thanks,
Weston
- neil_math_comp
- 1743 posts
Hi Weston! It looks like you have an extra right-double-quote character after the
/shop_materialpath1
text inside the string.
- neil_math_comp
- 1743 posts
I fixed the code block in goldleaf's post that seemed not to be liked by the forum's bbcode parser, so now anyone copying the code from his post in the future should hopefully get the correct quotes.
- weston.slater
- 4 posts
- neil_math_comp
- 1743 posts
Oh, if
objnode
isn't a Geometry object, there won't be a shop_materialpath
parameter. I guess the script will only work if the Object Merge SOPs are merging from objects, instead of directly from SOPs. You could probably check if objnode is type geo
, and if not, switch to using its parent. Putting omething like the following code before the evaluation line might work, (though I'm not great with Python, so I'm just guessing) :if objnode.type().name() != 'geo': objnode = objnode.parent()
- weston.slater
- 4 posts
That worked! Thanks a bunch, I really appreciate it!! Here's the code for anybody else curious:
Edit by ndickson: Removed an indent that would have skipped Geometry objects.
# Support multiple selected nodes for n in hou.selectedNodes(): # Only operate on Obj Merge SOPs if n.type().name() == 'object_merge': # Set variables for our nodes p = n.parent() m = p.createNode('material') objnode = hou.node(hou.parm(n.path()+"/objpath1").eval()) # Connect the material sop to the obj merge sop m.setInput(0,n) # Move it below the merge node m.moveToGoodPosition() # Point the material sop to the obj's material if objnode.type().name() != 'geo': objnode = objnode.parent() hou.parm(m.path() + "/shop_materialpath1").set(hou.parm(objnode.path() + "/shop_materialpath").eval())
Edited by neil_math_comp - 2018年5月11日 19:20:06
- neil_math_comp
- 1743 posts
I hope you don't mind that I removed an indent from that last line in your post, since otherwise it would have only set the parameter if
objnode
was not a Geometry object. I don't often edit other people's posts apart from forum formatting issues, but I figure if it's intended to be a reference for others and you don't mind, it's probably worth it.
- weston.slater
- 4 posts
- goldleaf
- 4255 posts
