how can i use batch render?
   11020   10   6
i want to render scenses by command line
because i can`t render several scenses together
will u give me a format
thank you
https://vimeo.com/user3971456/videos [vimeo.com]
> hscript
> mread my_scene.hip
> cd /out
> ls
mantraHQ
doprender1
mantraLQ
> render mantraHQ –f 1 100 –V –s
type: > help render for more help.
or:
> hython
> hou.hipFile.load(“my_scene.hip”)
> mantra = hou.node(“/out/mantraHQ”)
> mantra.parm(“camera”).set(“/obj/renderCam”)
> mantra.render()
… with changing render camera just before.
or create cmd file: render.cmd:
mread myscene.hip
render /out/mantraHQ
mread myscene2.hip
render /out/mantraLQ
# etc.
and call hscript with that file:
hscript render.cmd
hope this helps,
sy.
SYmek
> hscript
> mread my_scene.hip
> cd /out
> ls
mantraHQ
doprender1
mantraLQ
or:
> hython
> mantra.render()
mread myscene.hip
mread myscene2.hip
# etc.
hscript render.cmd
hope this helps,
sy.
that`s what i want thank you
hello guys,
I know that this topic is 2 years old but in case that someone see it.
I tried to render as you said and work nice except that when I am trying to override the frame range using -f StartFrame EndFrame, will be ignored and it will render hat ever is already set in the hip file.
Any help?
never mind I found the solution, it was very simple and now my question looks stupid.
I followed the instructions of SYmek:
Code:
> hscript
> mread my_scene.hip
> cd /out
> ls
mantraHQ
doprender1
mantraLQ
but for some reason it didnt worked for me by using the frame range at the end of the command. So I moved it at the middle after the “render” and before the “mantra” and works great.
> hscript
> mread my_scene.hip
> render -V –f 1 100 /out/mantraHQ
all label should befor rop “/out/mantraHQ”
luoqiulin
WOW some weird stuff…
it seems that you need to set the frame before the verbose command:
render –f 1 100 -V /out/mantraHQ
Batch render deserves its UI.
https://www.imdb.com/name/nm8408875/ [www.imdb.com]
Hello is it possible to have a cmd file that contains “hscript”?
If I type each command in “Command Line tools”, it works.
But I tried to create a render.cmd file that contains:
hscript
mread my_scene.hip
This does not work. The command prompt just says : “hbatch Version blah blah (Compiled on blah)”. Then nothing happens.
Thanks,
Gz
Edited by Grendizer - 2018年9月8日 08:19:21
Houdini gamboler
Hi Grendizer, did you ever find out how to make this work?
cheers,
A>
I make file HRender.sh + chmod+x …
#!/bin/bash
#Launch Houdini Batch Render
/opt/hfs17.5.xxx/bin/hbatch -c "render -v -f 1 /out/arnold1" "/path/MyFile.hip"
It's work fine on Linux,How I Can Render multi cam?
Hello guys, no I didn't find a way to start a batch render directly from a cmd or bat file. I have to launch the Hou Command Line tool then start my cmd file from here : hscript mybatch.cmd
I'm on Windows 10. I'd like to find a solution that works on Windows.
BTW since this post I learnt to use Hqueue
Houdini gamboler
