This feature available only on non-connected node,
after it's connected it is no longer available for editing.
Old projects also show this option as non accessible (grayed out)
so I can't export material_ID to Max the way I could.
Houdini engine also can't export material ID
my post in this thread
https://www.sidefx.com/forum/topic/58396/ [www.sidefx.com]
and there's no docs/tutorials about it.
maybe there's a different to export mesh from houdini -> max with mat_IDs
ROP Alembic Partition Mode does not work in 17
4625 4 1- gasanoff
- 14 posts
- derrick
- 329 posts
The Partition Attribute is only meaningful if you export an Object hierarchy. When exporting from a SOP, the “Build Hierarchy From Attribute” option gives you greater control over where things should be placed in the resulting Alembic archive. Consider enabling “Build Hierarchy From Attribute” and creating a primitive string attribute (identified by the “Path Attribute” parameter) specifying where everything belongs in the resulting Alembic archive.
- gasanoff
- 14 posts
- ianoreo
- 8 posts
- patar
- 280 posts
