3DCoat-Houdini Applinker
   31561   18   6
Hi.
I did 3DCoat-Houdini Applinker asset. It's possible to export-import meshes and export textures from 3DCoat. Very useful for modeling and texturing artists.
The asset: http://www.orbolt.com/asset/mifth::mifth_3dcoat_applinker [orbolt.com]
- Set the Exchange folder before exporting/importing. On linux it's at ‘home/user/3DCoatVersion/Exchange’. On Windows it's somewhere at user documents. 3DCoat creates such a folder itself.
- Tested on Linux. If you have any issues on Windows then write me here.
Video test of export/import of meshes and textures:
https://youtu.be/4WVgfgugZ5M [youtu.be]
3DCoat thread:
http://3dcoat.com/forum/index.php?showtopic=19145 [3dcoat.com]
Edited by - 2016年4月6日 06:04:16
Looking forward to this!
And! The asset is now at Orbolt!
Enjoy and test it!
Thank you
Hi ya, this is a very useful tool. could you update it for H16.5 please?
I've created a folder in 3dcoat 4.7.5 name ‘Exchange’ but it doesn't get accepted by the dialog box on selection.
Thank you!
Hi!
Actually it works in 16.5. All you need is just to copy the Exchange path. I'll fix it at Orbolt soon.
https://youtu.be/_JZVCWtCZCk [youtu.be]
I have just updated the asset at orbolt.
オンライン
Thanks man for your work!
Hi Paul,
I'm attempting to download it but I get an empty (0 byte) OTL file. I'm doing Manual Install btw, I can't install using Houdini at work.
Peter B
Peter Bowmar
____________
Strange it works OK at home. Nevermind, must be a quirk with my work machine.
Peter Bowmar
____________
Hi, can this be used on a Mac? Thx. Rob
Hi. I guess yes. If you set correct path.
It worked on linux.
Seems to load in 17. Even though DL page states compatibility with versions 13 to 15.5. What am I missing? 17 is back compatible. Correct?
All should work ok.
Unfortunately can't get this to work with H17.5. Some Python error..
Any idea why?
Edited by Werner Ziemerink - 2019年3月25日 04:18:37
Werner Ziemerink
Head of 3D
www.luma.co.za
Thanks for the report. Let me test 3dcoat again. I'll download it and get back soon.
Hello!
I investigated the problem. H17.5 uses relative paths by default. Just make Absolute path for the node you want to export.
Like this example:
I fixed relative path exporting. It will be V10 of the asset. The version 10 will be available at Orbolt in several of days.
Thanks for the report. Let me if all works fine now.
Edited by Pavel Geraskin - 2019年3月27日 07:06:29
Thanks, I will give it a go and report back here.
Werner Ziemerink
Head of 3D
www.luma.co.za
