Does this piece of code have some problem in the Python script of the HDA Processor node ?
   1929   1   0
It is a screenshot from the HDA Processor node's python module. I think the code that I highlight is for setting the HDA Processor node's parameter with the template_node's parameter.
But the parameter names in HDA Processor are all added by a prefix named "hdap_" actually, so the parameter's name in the HDA Processor will never equal to the original one.
As a result, I drop the hda node to the Template Node parameter of the HDA Processor node, the parameters do not initialize by the hda node.
Thank you for pointing this out! The fix will be available in the next daily build.
