I download a .usd file with Point Instancer inside it. I want to import the instancer points prim (not prototype) to sop for editing (edit point's position, count, size… ), and import back to lop network. I test many options, but all those can't keep PointInstancer.
How to import back to lop with keeping the PointInstancer prim type?
Thanks for any tips!
How to edit Point Instancer prim with Sop Modify?
3816 3 0-
- jerry7
- 681 posts
- mtucker
- 4566 posts
- jerry7
- 681 posts
- earlgeorg
- 6 posts
I've also found this node to be quite buggy, so I had to write a custom node that just applies all parameters of the points to the PointInstancer parameters in a python script node.
Also using this modifypointinstances node with setting the Point Instances parameter to "/points" will create a huge json array of every point internally, which will overflow the python scripts when having a huge amount of instances (> 10.000).
