Does Houdini have save auto-increment option?
7352 11 3- nick96st
- goldfarb
- 3456 posts
- martin-egger
- 30 posts
This feature was know to me as well, but it is quite useless as you don't want to get rid of your ability to simply save over your previous file and would create unnecessary amounts of workfile-data. Instead, what I always use is Niklas Rosenstein's great shelf script:
https://www.niklasrosenstein.com/post/2017-07-13-houdini-incremental-save/ [www.niklasrosenstein.com]
It's very versatile and pretty much unbreakable!
If Houdini were to natively adopt this as a feature next to the other save options (Like a lot of other DCCs already have), I'm sure a lot of artists would appreciate that in being able to cross one of their tools that they always have to reinstall off their list.
Edited by martin-egger - 2020年4月20日 09:09:52
- Martin Egger
Student at Filmakademie BW
& Freelance FX TD
& Freelance FX TD
- Jonathan de Blok
- 256 posts
I ran into the same issue so I made a nice little script. What is does is create a ‘rolling’ backup with a maximum of files being kept. After each save it will automatically check the scene's backup folder and deletes the older ones, keeping a fixed number of backup around. it keeps two types of backups, one is created every time you manually save the scene, and an ‘_auto’ one that is created at given intervals you can set in your Houdini prefs.
Unzip attachment and place both in your Houdini's document script dir.
(the 456.cmd turn on the ‘autosave’ for you, by default it's turned off when you restart Houdini)
In the zip you'll find the script below, the ‘max_files’ in the script is the max files to keep around.
#place in $home/scripts/afterscenesave.py #Jonathan de Blok import os import glob verbose_only=False max_files=15 file=kwargs["file"] if file.find('/backup/')>0: print "WARNING, saving into a backup folder.. skipped pruning" else: #prune auto backup files if kwargs["success"] and kwargs["autosave"]: files = glob.glob(os.path.dirname(file)+"/backup/"+os.path.splitext( os.path.basename(file))[0]+"*_auto*.hip*") files.sort(key=os.path.getmtime) for item in files[:-1*max_files]: if item.find("_auto")>0 and item.find(".hip")>0 and item.find("*")==-1: if not verbose_only: os.remove(item) print "Pruned autosave backup file: " + item else: print "would have Pruned backup file: " + item #prune normal backup files if kwargs["success"] and not kwargs["autosave"]: files = glob.glob(os.path.dirname(file)+"/backup/"+os.path.splitext( os.path.basename(file))[0]+"*_bak*.hip*") files.sort(key=os.path.getmtime) for item in files[:-1*max_files]: if item.find("_bak")>0 and item.find(".hip")>0 and item.find("*")==-1: if not verbose_only: os.remove(item) print "Pruned autobackup file: " + item else: print "would have normal backup file: " + item
Edited by Jonathan de Blok - 2020年4月20日 10:34:10
More code, less clicks.
- Jonathan de Blok
- 256 posts
- CYTE
- 685 posts
martin-egger
Does anybody have a backup of this script? I would like to use it. Unfortunately, it isn't available anymore.
CYTE
- bobc4d
- 320 posts
CYTEI clicked on it and it did downloadmartin-egger
CYTE
- CYTE
- 685 posts
bobc4dGreat would you be so kind and attach it here I get a 404:CYTEI clicked on it and it did downloadmartin-egger
CYTE
- hMonkey
- 85 posts
- hMonkey
- 85 posts
- CYTE
- 685 posts
- vvolfart
