HDA requires selecting faces from a group
   5306   6   0
I have a tool that takes a mesh as an input and also reveals a few group node (“Base Group”) fields for input.
However, I'm not sure what needs to go into the revealed group field for it to work. It only accepts meshes (which is fine), but it doesn't appear to actually use the data.
Can anyone explain to me how this works?
Hi alfyou,
I'm not quite sure what you mean by “revealing” a few group nodes. Are you trying to provide your digital asset with a face selection from Maya?
Hi John,
Apologies for not being clearer. I have a few group nodes (see attached) that require selection based on the geometry that I've set as the sub-network input.
How do I provide mesh or face selection into this field where it will properly utilize it?
(fields have been cleared in image)
Hi alfyou, unfortunately the current method of specifying groups is less than ideal. You need to specify the component ids just like you would with the attribute ids inside of Houdini. Improving the UX of this shouldn't be difficult to implement, so I should be able to get to it by early next week.
In the mean-time, the easiest way to get these values is to select the components that you want to be part of the group, then run the following script in the Python script editor:
from maya import cmds
def get_selected_components(component_type):
    components = []
    sel_mask   = -1
    type_name  = ''
    if component_type.lower() == 'vtx':
        sel_mask = 31
        type_name = 'vertices'
    elif component_type.lower() == 'e':
        sel_mask = 32
        type_name = 'edges'
    elif component_type.lower() == 'f':
        sel_mask = 34
        type_name = 'faces'
    elif component_type.lower() == 'map':
        sel_mask = 35
        type_name = 'UVs'
    else:
        cmds.error('Unknown component type. Must be "vtx", "e", "f" or "map".')
    components_raw = cmds.filterExpand(cmds.ls(sl=True), sm=sel_mask, ex=False)
    if not components_raw:
        return None
    for component in components_raw:
        lidx = component.find('[') + 1
        ridx = component.rfind(']')
        if lidx <= 0 or ridx <= 0 or ridx <= lidx:
            cmds.warning('Could not determine %s index of "%s"' % (type_name, component))
        components.append(component[lidx:ridx].replace(':', '-'))
    return ', '.join(components)
def run_get_selected_components():
    print 'Selected components\n--------------------------------------------'
    print 'Vertices:', get_selected_components('vtx')
    print 'Edges:   ', get_selected_components('e')
    print 'Faces:   ', get_selected_components('f')
    print 'UVs:     ', get_selected_components('map')
This will print out the components that you need to specify in the group field in the digital asset. It will look something like the following:
Selected components
Vertices: 1860-1866, 1912-1914
Edges: None
Faces: None
UVs: None
Edited by johnmather - 2020年4月2日 15:21:29
Hi John,
Ah! Ok I get it now. Thank you for the script and clarification on the use of component IDs! I'll add this to our toolset in the meantime.
Hi Alfyou,
This has been implemented, and will be available in tomorrow's builds - 18.0.430 and 17.5.581.
More information can be found here: https://www.sidefx.com/forum/topic/72894/?page=1#post-308341 [www.sidefx.com]
johnmather
Hi Alfyou,
Totally missed this. Thank you!!
EDIT: BTW this is soooooo satisfying to use….
Edited by alfyou - 2020年7月1日 19:06:52
