Hi there,
I've been playing around with the ocean tools and ran into a weird issue when I render the scene.
When the ocean intersects with geometry (in my case, when it hits the beach), you can see a dark line
where the geometries intersect.
Depending on the angle of the intersection, the lines get more or less visible.
Has anyone ran into a similar problem? It might be something really obvious, but I can't find a solution
to this.
I've attached a test scene and an image. Maybe someone has an idea.
Thank you!
weird dark lines where ocean intersects with geometry
4251 6 1-
- Hendolph
- 12 posts
- Hendolph
- 12 posts
- protozoan
- 1942 posts
- オンライン
- Hendolph
- 12 posts
thanks Martin, this definitely helped when I set it to 0.00001 from 0.001. didn't remove it completey, but it's a lot less visible. It did however create weird striation artefacts in the direct shadow pass, that are not visible in the beauty, but become visible when I decrease it further. But I don't think I need to decrease it further. If it's still visible I can probably also mask the intersection area somehow and lower the opacity.
anyway, thank you so much for your help!
- Hendolph
- 12 posts
I don’t suppose any has an answer to my displacement texture question as well?
Last time I used the ocean tools for a job (probably 5ish years ago), I remember having to select the exported texture in the oceansurface shader. And now there is no parameter for it. Makes me wonder if I still need to export the texture at all.
- 8381 posts
- オンライン
Hendolph
Exported textures are optional for mantra, but they're mostly for use with other renderers that don't have mantra's ocean procedural.
- Hendolph
- 12 posts
