At 10:35 in the Houdini 18 launch video it seems like Scott switches on ‘Show All Objects’ and sees outside the instancer to the Solaris scene in the viewport. I've been unable to reproduce this from an Instancer / SOP Modify / any other SOP-node, but would LOVE to be able to. Seeing the Solaris scene when you're modifying geometry in SOPs is pretty crucial.
Hopefully I'm just missing something obvious? Link to the presentation: https://youtu.be/Aql6SIOIyXs?t=634 [youtu.be]
Ghosting Solaris scene from inside SOP Modify / Instancer
3498 8 2- blented
- 61 posts
- Galleryworm
- 21 posts
I'm running into this same issue. Whenever I use the “instance to points” node with the internal sop method, I am unable to see my results after I scatter points without going back up a level regardless of whether or not my viewport is set to ghost geometry and or show all objects. Has anyone else encountered this?
- mtucker
- 4444 posts
- Galleryworm
- 21 posts
- Galleryworm
- 21 posts
- mtucker
- 4444 posts
- aweaklingchild
- 23 posts
- Galleryworm
- 21 posts
- jerry7
- 626 posts
