Hi!
I am quite new with Houdini but this sounds so simple that I SHOULD be able to figure it out but so far not even close
I have an edge group that I want to turn to polygon(s) i.e. each connected loop would make a polygon. Those are flat so no problems like that but I cannot find a way to do it
There is probably some simple node that does it but I have tried many but none does what I need.
Labs Edge Group to Curve does what it says but I need Edge Group to Polygons node
I know it can be done in VEX but there must be simpler way with nodes only.
Please help me
Thank you!
Antti
Create polygon from edge group? Should be easy but...
1273 3 1- atnreg
- 57 posts
- CYTE
- 683 posts
- vusta
- 555 posts
- atnreg
- 57 posts
Hi!
Thank you CYTE, I knew there was some easy way and that is it! Works perfectly!
Vusta, polyextrude does it wrong way, I wanted to get the polygon from edge group that is the outline of the polygon.
Thank you both for your time!
Antti
Antti
My system:
AMD Ryzen Threadripper 2990 (32-core),64GB RAM,NVIDIA RTX 3090,Win10
UE5.1,Houdini 19.5 Indie(always latest daily),Blender,Clarisse,Onyx,ZBrush...
Clarisse 2016-09, Houdini 2018-05 (seriously 2019-10)
I do all 3D for fun, no business
