Hi.
I am trying to understand the use of the sublayer LOP. I have watched enough Pixar and SideFX presentations to get that I can have my geo all nicely UV’d in one sublayer and somehow have only the anim point info in the next sublayer, thus making anim caches light and independent of UV’s etc.
So right now I have two usd files. One with just the geo and the other the entire mesh/UV/anim data. I want to create an anim usd file that only contains the point anim data. How do you go about only saving out the point anim data using a usd ROP?
Have I got this right in my head?
Thanks in advance for any help on this.
Mark
Understanding the use of Sublayer
3609 4 3-
- Mark Wallman
- 739 posts
- mtucker
- 4560 posts
- Mark Wallman
- 739 posts
Hi Mark
Sorry I might not have explained it properly.
Sphere_geo contains: Model, UV
Sphere_anim contains: Model, UV, Anim
If I add a layerbreak all I am effectively doing is loading in Sphere_anim and saving it out again, with all the data. I want to create an Sphere_anim.usd file that only contains the point anim data.
Or am I looking at this the wrong way around?
Should I manually delete the UV's (SOP modify) on the sphere_anim and export so the sublayer above which holds the sphere_geo has the higher opinion strength on UV's.
In theory I can understand what sublayering should be doing. It is just putting it into practice. ;-)
Best Mark
Best Mark
- mtucker
- 4560 posts
Oh, sorry... In that case I'm still not sure I'm following... You're looking for a way to strip the model/UV data out of sphere_anim.usd?
I would say that ideally you should have never written the model/uv data into sphere_anim in the first place (which is where the Layer Break would come in handy). But perhaps the sphere_anim file is coming from some other package/process that doesn't allow you to restrict the data saved to the layer?
- 9288 posts
- オンライン
