Hi there,
Unreal needs special uvs on uv2 for lightmaps.
Idealy they should look rectangular and not diagonal.
They should also be quantised to pixel resolution.
Tips? I cant get this to work with the Houdini tools in H16.
kind regards
Olaf
Houdini creating UVs for Unreal lightmaps
7117 5 3- Olaf Finkbeiner
- 323 posts
- ZN-Games
- 19 posts
Hi Olaf,
Im switching my current project from realtime to baked lighting and had the same problem today….
You can use layers to create several uv sets.
https://www.youtube.com/watch?v=U90eHb8OLr4 [youtube.com]
You can also create a hda with several layers and they should show up as different uv sets in unreall
Best regards,
Johannes
Best regards,
Johannes
Edited by ZN-Games - 2017年4月17日 15:15:20
- Olaf Finkbeiner
- 323 posts
Hi Johannes,
i figured it out by now.
this is very usefull
https://www.orbolt.com/asset/mifth::mifth_uv_grid [orbolt.com]
I also made a little tool to make sure the uvs are pixel perfect.
thanks
Olaf
thanks
Olaf
- ajz3d
- 478 posts
- Noboru_Garcia
- 75 posts
- FJSam
- 18 posts
Noboru_Garcia
What are the requirements to get the UV's to work properly. Evertime I export as a HDA the same asset refuses the work properly. But if I simply export as FBX it works! I'm baffeled.
Here's a video I made on the topic. Might help someone!
https://youtu.be/ZGMrwwKglKE [youtu.be]
