Materialx node need not compile at runtime?
   1940   2   2
I noticed the materialx node's parameter gives faster feedback without promoted than vex vop.
Does not it need to compile at runtime?
What is the backend of Materialx node? C++ or some other thing?
Edited by jerry7 - 2021年11月15日 22:04:53
MaterialX is in XML why it is faster i don't know.
What could be is that USD and MaterialX are newer concepts how to handle data and the vex compile was just a speedup of a older data construction (ifd or cross compile in USD).
https://github.com/materialx/MaterialX/blob/main/resources/Materials/Examples/Syntax/NodeGraphs.mtlx [github.com]
I'd assume that if you use MaterialX with Karma CPU it would still need to compile the VEX node graph or code inferred from MaterialX graph as usual
CG Supervisor
Framestore, NY
