Import Hou in External Python Process
   5359   4   2
Hey everyone,
I'm getting this error when I'm trying to import hou in an external Python process. I've tried setting the windows path variables to no avail. There are a few other forum posts on this but no real solutions. Any ideas?
File “C:/Users/ryan/AppData/Local/Temp/houdini_temp/ML_PDG_v006/pdgtemp/26912/pythonscript2_3.py”, line 9, in <module>
import hou
File “C:\Users\ryan\AppData\Local\Programs\Python\Python37\lib\hou.py”, line 28, in <module>
import _hou
ImportError: DLL load failed: The specified procedure could not be found.
Same questions... input would be most welcome.
This is just for 2.7 - I need 3.x:
https://www.sidefx.com/docs/houdini/hom/commandline.html [www.sidefx.com]
m.
I've encountered this issue too using python 2.7 in Windows.
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
Are you using hython or python when you get the error?
Python. Interestingly it works fine on my workstation, I just can't identify the cause for why it occurs in some other systems.
