setdetailattribute min
   2832   9   1
Hi! Just wondering if the minimum function of setdetailattrib is dead
f@dog = {11, 30, 5};
setdetailattrib(0, 'max', @dog, "max");
setdetailattrib(0, 'min', @dog, "min");
returns
max 11.0
min 0.0
H17.5.260, linux
It works…just depends on how you are using it.
For starters..your trying to assign 3 values to a single attribute - f@dog.
So it only takes the first value of 11. That's why you get a max of 11 instead of 30.
Since there is no min value…it defaults to 0.
Create a polygon sphere and in a wrangle set to run over points put the following and you will see the function does work:
setdetailattrib(0, 'max', @P.y, "max");
setdetailattrib(0, 'min', @P.y, "min");
thanks - that works but then why doesn't it for for the @speed attribute of the attached. The Max works but not the min.
speed.hipnc (309.5 KB)
Yeah, that's strange…I think it is a bug.
I mean it works with @v.
But if before the wrangle with setdetail, I add a wrangle and doing something like this for normals:
@N = set(rand(@ptnum) + 1, rand(@ptnum+2) + 1, rand(@ptnum+3) + 1);
Setdetail still returns 0 for all components.( at ‘best’ min should be no less than 1 )
But if I use a sop to set normals, setdetail works fine.
Edited by BabaJ - 2019年6月1日 21:50:53
I think you are misunderstanding what min and max mean in this context. The token at the end of setattib() functions determines how the value is recorded.
the normal way, ‘set’, replaces the existing value with the new one.
'multiply', ‘min’, ‘max’, ‘add’, etc perform that operation to combine the existing value with the new one.
For example, if you set the values of ‘P’, to {1.0,1.0,1.0} with a min operation, all the points left of 1.0, below 1.0 and behind 1.0 units from the origin will be unchanged, the rest will be set to 1.0.
In your examples, I presume the attribute named ‘min’ and ‘max’ do not yet exist. When performing a ‘min’ or ‘max’ operation, the existing values are assumed to be 0, and the operation uses 0 as the first operand and your new value as the second.
There are other functions called min() and max() that work on vectors or arrays to return the highest value or lowest value contained therein.
Edited by jsmack - 2019年6月1日 22:09:43
setpointattrib_ex.hip (124.3 KB)
okay, does that mean to normalise the min, max values of the @speed attribute, in the example, then I need to use an attribute promote Sop? Would prefer a vex solution if possible.
goat
just make sure your speed_min default is a big number
you can either initialize it before
or if you need in the same wrangle you can use adddetailattrib()
adddetailattrib(0, 'speed_min', 1e10);
setdetailattrib(0, 'speed_min', @speed, "min");
thanks @tamte - that works beautifully.
So..it's sort of a ‘bug’.
If there is no attribute to begin with and it's assuming a value of 0.0,
Then the first ‘set’ operation is creating the attribute.
No reason why that initial creation could not branch an operation to use the current value as the starting point.
I'm guessing there is a bit of legacy coding going on here.
Like wasn't there at one point in time something like not being able to set a non-existent attribute. But now we can?
tamte
Thank you!!! I had this set in an upstream wrangle but still had rounding, putting it in same wrangle fixed. thanks
