how i can randomiaze albedo color on instances in karma
   4467   6   1
if for instances i have some trees instanced and i want some variation on the albedo just for the leafs?
That might be helpful for you.
https://youtu.be/Aql6SIOIyXs?t=692 [youtu.be]
Edited by jomaro - 2022年4月9日 19:52:54
i followed that video time ago but i dont understood where he find that "leaf tint" attribute, that video don't explain very well the all steps, i see also that in solaris thereis a node called material variation.... why they don't put more effort to explain what it's the best workflow to tackle this....
Edited by Piledriver - 2022年4月11日 07:06:34
In the Material variation node, put something like this:
value = random(@elemnum);
https://www.sidefx.com/forum/topic/76074/ [www.sidefx.com]
Piledriver
What about this
https://youtu.be/SUvFaCAbyZ4 [youtu.be]
Be aware that there is still limitation on instancing and materials:
Listen to this...
https://youtu.be/n0-oSubrggA?t=578 [youtu.be]
Edited by jomaro - 2022年4月13日 11:41:18
i'm looking to a method that can have control not only to randomize colors but also controlling the saturation like arnold does with ai jitter node, anyway thanks for the links i'll follow them,i've seen also with color correct node and try to change the saturation control but seems not working xD
Edited by Piledriver - 2022年4月14日 15:07:47
Piledriver
You can create attribute randomize inside sop level after your object and inside your material network use bind to connect it to hue.
