I want stitch uvs in Houdini like in Maya. When you select uv edge and select stitch, it will stitch with the shared edge with neighbour polygone and will rotate.
Is this workflow possible in Houdini?
Stitch Uvs like in Maya
1370 3 1- seeplus
- 33 posts
- 7840 posts
- 8622 posts
jsmackI believe that should be irrelevant
What happens if the edges have different numbers of vertices and/or are different shapes?
I can imagine that every 2 UV islands of manifold mesh share exactly the same number (0+) of edges in 3d space
So technically should be possible to compute best fit transform for the island to get all of them the closest possible and then just snap/reflatten from there
I don't recall if any of the current UV tools does such operation or if you'd have to build it (Extract Transform SOP and Transform Pieces SOP should get you 90% there)
Edited by tamte - 2022年8月22日 00:07:26
- seeplus
- 33 posts
