RS vs Karma XPU massive difference help
2169 4 2- traileverse
- 355 posts
in the images below I have the RS render (which is what I expect to see), and karma XPU, which is far from what I expect to see (I tries using OCIO transforms to ensure color space parity, which makes no difference) and karma CPU render which is a bit better than XPU but still has a big issue. The second screen close to the keyboard has the texture all blurred out. The way this is setup is that there is a plane for the screen and another plane above the transparent plastic covering (the material has almost 0 specular roughness), so I tried rendering the screen plane alone using XPU and it's not blurry. The main screen is setup exactly the same way and is using the exact same transparent plastic material and the screen texture beneath is visible and not blurry so I don't think the material is the problem. Next, why are the Karma renders so dark? I increased diffuse and reflection limits and no change.
hou.f*ckatdskmaya().forever()
- cgfrankie
- 9 posts
- Hamilton Meathouse
- 174 posts
- traileverse
- 355 posts
- goldleaf
- 4170 posts
