Hello
I'm wondering if it's possible to inspect volume attributes in the stage context?
I created a volume in the obj context.
I imported it inside the stage using a scene import node.
I want to check the min and max range of the density attribute.
I tried to select a node then go to geometry spreadsheet > primitive mode, but it's all empty.
Thanks and see you soon,
GS
Inspecting volumes attributes in the stage context
1179 3 2- Grendizer
- 375 posts
- Grendizer
- 375 posts
Hey Grendizer you have to use the "Scene graph details" window. Look for "primvar" values.
However, what's the best way to use several primvar values in a MTLX material library network node? For example I want to get the min and max density, min and max flame, min and max temperature, etc...
Houdini gamboler
- AslakKS
- 160 posts
- Grendizer
- 375 posts
