work item hanging for a long time
   3089   3   2
[18:39:29] PDG: (localscheduler1) ('Local Scheduler: Max Slots=23, Working Dir=F:/Houdini/test',)
[18:39:29] PDG: (localscheduler1) ('onSchedule [0/23 S:False]: prev_2908',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2889',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2890',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2891',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2892',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2893',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2894',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2895',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2896',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2897',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2898',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2899',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2900',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2901',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2902',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2903',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2904',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2905',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2906',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2907',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2909',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2910',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2911',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2912',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2913',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2914',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2915',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2916',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2917',)
[18:39:31] PDG: (localscheduler1) ('onSchedule [0/23 S:True]: prev_2918',)
hi, i got this log when i using pdg rop fetch work items with scheduler verbose logging, Previously, it was okay.
now it will run for a long time without continuing to next work item and keep printing this information。
Has anyone encountered it before?
Sounds similar to this post from today
https://www.sidefx.com/forum/topic/90982/ [www.sidefx.com]
I also experienced some endless cooking on my topnet.
What is the best setup to render Karma XPU multi cam outputs?
Is it really necessary to write out the .usd file first? Or are there other methods?
I attached my screenshot. Any advice would be welcome. It's annoying to have this endless cookings.
I have still the problem, that on a certain point, mostly after rendering 10-12 outputs, a ROP USD OUTPUT NODE cooks forever and
if I try to quit the job, Houdini is hanging.
I attached a test scene to show you my setup. This will run from start to end, because it's a very simple scene.
But maybe there is something, to optimze the flow?
Thanks for any help
Tom
Multi_Render_Setup_KarmaXPU.hiplc (2.0 MB)
