Hi, is there a vex function (or node) that finds the closest PRIMITIVES to a specified point position? Something that looks within a certain distance? I need to find multiple primitives...not just one.
Thanks,
Find Closest Primitives to a point
1941 19 2- TheDude123
- 66 posts
- animatrix_
- 4523 posts
TheDude123
Thanks,
There is no single function that can return multiple nearest primitives but you can use xyzdist iteratively and use adhoc group to continuously exclude the previously found prims as you go, but it will be slow depending on how many primitives you want to gather as each call with a changing adhoc group will rebuild the acceleration data structures.
- TheDude123
- 66 posts
animatrix_TheDude123
Thanks,
I see, bummer. Thanks for the info. I'll try the xyzdist method. I have ~50,000 points to loop over and find their nearest prims within a given radius.
So, each point will probably find 3-5 prims. Not sure how slow that's going to be.
Edited by TheDude123 - 2024年1月5日 12:54:13
- TheDude123
- 66 posts
- 8583 posts
TheDude123
doesn't matter how many points you have, its more about how many prims in the lookup geo and how many unique acceleration structures it needs for your points, there is still a high potential for reuse or many points may not even find any prim within radius so they will never get past the default xyzdist call
but it's easy to try and see how fast/slow it is for your case
Edited by tamte - 2024年1月5日 22:16:30
- animatrix_
- 4523 posts
TheDude123
Here is an example of what I'm trying to do:
This will be looped over ~50,000 points
In this case you can also store the primitive number on the points and do a regular point cloud lookup using pcfind and then loop over these points to gather unique primitive numbers found. This should be much faster for the vast majority of cases where you don't have an overwhelming number of points to filter through.
- Aizatulin
- 477 posts
You can also try to (pre)filter the primitives using their (local) bounding box, because the distance from any point to the bounding box is always less or equal compared to the distance itself. But the prefiltered distances doesn't need to have the same order as the original distances, so if you want to use something like maximum search number, you need more points to be sure to get all (or maybe check the maximum distance to the primtives aswell).
- TheDude123
- 66 posts
Thanks everyone for the help! I'm running into another issue though: I've found an attribute on the points (of the primitives found) and I'd like to store those values into an array of values (they are float values, btw). I can't seem to find a function that will do this. Basically, create an array from an attribute that exists on multiple points (and has different float values).
Example:
point0 f@attribute = 2.3
point1 f@attribute = 73.3
point2 f@attribute = 54.34
point3 f@attribute = 22.6
point4 f@attribute = 5.3
point5 f@attribute = 67.3
create array {2.3, 73.3, 54.43, 22.6, 5.3, 67.3}
Any suggestions?
Example:
Any suggestions?
Edited by TheDude123 - 2024年1月7日 12:44:03
- animatrix_
- 4523 posts
TheDude123
Example:
Any suggestions?
What you are looking for is a pointmany VEX function. It doesn't exist. There is an RFE for this: SESI #19043. Submit an RFE and reference this number so they can bump it up.
For now you have to do it manually:
float vals [ ] = array ( ); int pts [ ] = array ( 1, 2, 3 ); foreach ( int pt; pts ) { float val = point ( 0, "attrib", pt ); append ( vals, val ); }
- TheDude123
- 66 posts
Example:
Any suggestions?
For now you have to do it manually:float vals [ ] = array ( ); int pts [ ] = array ( 1, 2, 3 ); foreach ( int pt; pts ) { float val = point ( 0, "attrib", pt ); append ( vals, val ); }
ooooooooh, thats interesting.
It looks like the 'manual' part, besides the writing of the code, is I have to input the amount of points into:
int pts = array(manually input here) correct???
Something likes this seems to work as well:
f@vals = array();
int pts = expandpointgroup(0, "");
foreach(int pt; pts){
float val = point(0, 'angle_diff_C', pt);
append(@vals, val);
Edited by TheDude123 - 2024年1月7日 13:23:30
- animatrix_
- 4523 posts
TheDude123animatrix_TheDude123
Example:
Any suggestions?
f@vals = array();
append(@vals, val);
If you want all points, you can use either:
expandpointgroup ( 0, "" ); expandpointgroup ( 0, "*" );
- 8583 posts
- TheDude123
- 66 posts
tamte
Not sure how is expandpointgroup() gonna help in your case
If you say you found some prims and now want attrib array of all points of one or all of those prims then it's more like you need to use primpoints() to get array of points per prim
I wasn't sure what you meant by this, and then I ran into the problem, LOL. The damn expandpointgroup() was returning ALL points. So...I used another array I had created (that included only the points within a certain distance to my search point...a nearpoints) and that seems to work.
Thanks for the warning!
- 8583 posts
TheDude123To me it sounded like you wanted to get closest prims within radius and then get points of those found prims and get the attrib value array from them, that's why I suggested primpoints()
But whatever works for your particular case, since it's not very clear to me what exactly you were trying to get
- TheDude123
- 66 posts
tamteTheDude123To me it sounded like you wanted to get closest prims within radius and then get points of those found prims and get the attrib value array from them, that's why I suggested primpoints()
I wanted to try both. Wasn't sure which would work the way i needed.
I was trying to fuse curves together that had overlapping points. HOWEVER, I need to run different checks so they wouldn't all fuse together. I only wanted the points with the smallest vector angle differences to fuse together (so there was a nice flow from curve to curve).
Another part was making sure each curve had a correct 'level' attribute that was calculated by looking at the closest prim/point to its root and adding 1 to the previous level found.
I think i got it working, probably way to overcomplicated...but I think it's working...until I click on another node down the chain
Edited by TheDude123 - 2024年1月9日 12:05:38
- Jikian
- 131 posts
TheDude123
Example:
Any suggestions?
Attribute Promote (to Detail), "Array of All"?
- TimOrSomething
- 10 posts
Thanks,
Hey, I just need the second closest prim but can't figure out the syntax of how to add the closest prim into the group to ignore. I tried something like this but wasn't working haha.
float closestPrimDist = xyzdist(1, @P, closestPrim, closestUV); float secClosestPrimDist = xyzdist(1, '!closestPrim', @P, secondClosestPrim, secondClosestUV)
Any help would be appreciated
Edited by TimOrSomething - 2024年3月11日 03:28:25
- animatrix_
- 4523 posts
TimOrSomethinganimatrix_TheDude123
Thanks,
Hey, I just need the second closest prim but can't figure out the syntax of how to add the closest prim into the group to ignore. I tried something like this but wasn't working haha.float closestPrimDist = xyzdist(1, @P, closestPrim, closestUV); float secClosestPrimDist = xyzdist(1, '!closestPrim', @P, secondClosestPrim, secondClosestUV)
You can do it like this:
int closestPrim = -1; vector closestUV = 0; float closestPrimDist = xyzdist(1, @P, closestPrim, closestUV); string excludeprim = "!" + itoa ( closestPrim ); int secondClosestPrim = -1; vector secondClosestUV = 0; float secClosestPrimDist = xyzdist(1, excludeprim, @P, secondClosestPrim, secondClosestUV);
Just passing closestPrim as an adhoc group won't work because a primitive group with that name doesn't exist. If you create that group in the same wrangle, then you would have to do the second lookup using another wrangle that comes after so it can find it.
- TimOrSomething
- 10 posts
animatrix_TimOrSomethinganimatrix_TheDude123
Thanks,
You can do it like this:int closestPrim = -1; vector closestUV = 0; float closestPrimDist = xyzdist(1, @P, closestPrim, closestUV); string excludeprim = "!" + itoa ( closestPrim ); int secondClosestPrim = -1; vector secondClosestUV = 0; float secClosestPrimDist = xyzdist(1, excludeprim, @P, secondClosestPrim, secondClosestUV);
Ah I see. Thanks a bunch!!
- TheDude123
- 66 posts
JikianTheDude123
Example:
Any suggestions?
haha, Yeah, that works too! Super Simple.
Thanks so much!
Edited by TheDude123 - 2024年4月13日 20:33:17
