Modeling a Robot Character Recorded Journey.
2324 9 3- fusion9
- 44 posts
Hello everyone, I wanted to share some of the progress I've been making with a robotic character I'm modeling right inside Houdini using the Modeler plugin.
Some bit of history.
Way back in the day, I learned to model rudimentarily in Maya. Then, I switched to Cinema4D as a general tool. Along the way, I felt a void in the modeling department, and that's when I discovered Modo. Modo is the app that really allowed me to learn how to model using SDS. This all happened in the best part of a decade. Fast forward to recent times, and I decided to completely switch to Houdini (about 3 years ago) and drop everything else to reduce costs and focus on my favorite workflow, which is Node-based. I would have started modeling in Blender if not for the existence of Modeler, but luckily I was able to do everything within a single program.
Objective of the stream.
My main objective is to improve my modeling/design skills in Houdini and really take advantage of Modeler. You can see me discovering and practicing tools as I go.
Also, I aim to improve my English while streaming.
Once the model is done, I plan on recording a comprehensive tutorial/walk-through, going over the whole process. I understand that watching the raw process can be boring at best.
Another plus for me is having an in-house production model to tackle another challenge, and that is mechanical rigging. I've been learning KineFX since its release, but not being a trained rigger, the process has been slow but very gratifying. There is also the milestone of porting the rig to Apex down the line.
Lastly here is a link [youtube.com] to the playlist where I'm uploading all the recorded sessions to.
Edited by fusion9 - 2023年12月26日 18:08:23
- fusion9
- 44 posts
I've already done some R&D on the rigging for the hand. It is based on Captured Packed, so the geometry stays packed, and the performance is great as a result.
Here is another R&D of a Mechanical Arm with multiple joints and multiple axial constraints. I just wanted to say the Configure Joint node is a godsend for this kind of work; otherwise, it would have been impossible for me to do it.
Edited by fusion9 - 2023年12月26日 18:14:11
- fusion9
- 44 posts
- fusion9
- 44 posts
- fusion9
- 44 posts
- fusion9
- 44 posts
- fusion9
- 44 posts
- fusion9
- 44 posts
- PolyMarvels
- 884 posts
- fusion9
- 44 posts
